John Deere 6400
Chad cole
It appears to be leaking hydraulic fluid around the pump on the back of the tractor. There is some sort of red filter looking thing that?s screwed on top of the pump. It appears to be leaking out around that. Can anyone tell me what that part is or how to stop this constant dripping
As I recall, there were several versions of hydraulic pumps used, and some or all had a little reserve reservoir connected to the top of the pump.
There is a large line to it from the "charge pump", a small "air vent line", and the o-ring fitting where it attaches to the pump.
Are either of those lines, or their connections, or the connection to the pump leaking, or is it the little "tank" itself leaking?
I'm not sure WHY it would be "red", perhaps it's possibly been repaired before, and that's the color someone had at hand???
There isn't a great deal of pressure in that main pump charge system, but there's apparently surges under certain conditions as I've seen the large line that's hose clamped on pop off a time or two, especially in cccold weather, when the oil is thicker.
Take a close look and post back with more details.
