(quoted from post at 15:10:59 02/28/22) Gotta be a breather someplace. Work through that.
(quoted from post at 10:25:36 03/03/22) If yours is old like mine are you forget the multipurpose lube...aka 90w gear oil, and fill it with Lubriplate 105 engine rebuilding grease...its viscosity is between 140w gear oil and #2 grease and stays put. Also solves leaking rotary cutter lower shaft seals....along with a vented fill plug on those.
