John Deere 70 Riding Mower
Carter W
I inherited an old JD 70 riding mower with a Tecumseh engine. I took it out today and ten minutes into my run it died like a flash. It won"t start now. It turns over fine but all I get is a pop, pop, pop out of the carb and exhaust. Then when I stop trying to turn over the engine white smoke comes out of the carb and exhaust.
Plenty of gas and spark.
Is my inheritance about to cost a lot of money?
Thank you.
Crank eng & check for spark,if you have,try installing a new spark plug,if that doesn't cure problem,check carb for a sticking/stuck float or leaking float valve causing eng to flood,after that check for leaking valves or a leaking/blown head gasket
I have one of those but mine has a 5 HP B&S which is not the original. I believe it came with a 7. Sure wish I had either one because the one in it needs replacing.
I like the little tractor. I bought it for my grandson but he has no interest in it. Even have a deck that I have never put onto it.
