John Deere 71 corn sheller
tomstractorsandtoys
I picked this up today from an online auction about an hour away. It looks to be in very good condition and runs nice and quiet. I have a manual ordered and hope to shell some corn this fall with it. Anyone else have one or any experience with a 71? Guessing by the decals it is one of the latter ones built. Tom
Ran one like it for years. We had 40 feet of drag line. If set up right it could do a lot in a hurry. Only one lever for adjustment opening or the cage. We put canvas down where the hogs could not clean up afterwards.
Looks like a copy of an MM. I've never seen one. The JD we had was a boxy little thing, with no intake elevator, and a tiny little blower to push the shelled corn up a pipe, which was always plugging.
So what you have is a stationary rotary combine!
After the dairy cows went Pa got one to shell out the cribs. He liked it and if I recall it did a good job.
My cousin had one. He also made an enclosed wagon that the husk would blow inot. He ran it with his new John Deere 50, The year was 1956.
How did you get it home with that tire? We had a couple MM. Some custom sheller went around here with a JD. sheller on a 50 Chevy. Don't know what model.
I agree with Bob B. It looks a lot like a copy of an MM. We ran our MM model "D" just recently (Sept 18 at Farmamerica) and I was thinking the similar thing that the "modern" rotary combines are patterned after some older corn shellers.
that is a neat find! looks like it is in good shape.
pieces of old equipment is getting harder to find,
im glad people can still find stuff like this before the scrappers get it!
We had one of them JD shellers like Bob Bancroft described. I guess when the intake elevator quit working (I left home) dad got rid of it.
(quoted from post at 07:46:57 09/26/20) This may sound like a stupid question but ... what does a corn sheller do?
Not a stupid question.
Back in the day when corn was picked on the ear and put in a corn crib, you would need to run it through a machine like this to shell it--in other words, separate the kernels from the cob. Then you could haul the shelled corn to town and sell it. Now days, this is done right in the field by the combine.
Hope that helps.
i ran a corn sheller for several years for a guy it was mounted on truck chassis,do not remember the model seems like it was single number. oh those were the days when had lotsa energy and met alot of the surrounding folks in about 50 mile radius. now days most do not know what ear corn is
We ran both Moline and JD custom shelling. Jd would usually provide a cleaner sample and was a good machine, just don't want any rocks in it. The main shaft ran lengthwise through the machine with no center support bearing. getting a rock in the threshing cylinder would bend the main shaft and it was a bugger to get straight again. Usually meant dismantling and removing shaft to get it in a press.
The Moline however had a carrier bearing ahead of threshing cylinder and would keep the shaft straight limiting damage to cylinder bars.
Rocks would get in the corn through the picker which was running close to the ground. Cultivating corn would provide an opportunity to roll rocksi into the row awaiting an opportunity to cause havoc to the picker or sheller
