John Deere 7520 Pistons??
Patjrose
looking for new OEM pistons for 6531A john
deere engine, part #AR53225 or AR53227. All
aftermarket suppliers have discontinued
overhual kits, and I have exhausted all my
resources within deer. I have 6 new sleeves
but only three new OEM pistons. Looking for
three more. Any help would be much
appreciated!!! Thanks,Pat!
Yes have pulled 6 sleeves from malon. 3 pistions form grimsby and 1 piston from another dealer as of this morning
Thanks!
I'm not sure how JD works there parts locator. I'm wondering if that engine was used in industrial machines and if so maybe the industrial dealers have a different parts locator ?
(quoted from post at 16:37:57 05/07/20) John Deere sometimes is a little slow mine still shows a 3020 short block available
SV
May I ask what website you utilize to search for JD parts availability?
I agree JD parts website isn't a good as it was before they "updated it"!
(quoted from post at 09:29:33 05/07/20) I'm not sure how JD works there parts locator. I'm wondering if that engine was used in industrial machines and if so maybe the industrial dealers have a different parts locator ?
According to my part # search on JD part's website the PN AR53225 only reveals 4 machines that utilize that piston.
Also had the thought of using 6531T psitons, different part number but all spec and mesurements seem to be the same as the 6531A pistons. Rod, crank, cam, head , valve train all have same part numbers. 6531T pistons are available...
Is that a difference between a turbo and non turbo engines ? IIRC turbo engines run a little lower compression ratio. Are you running a turbo ?
The difference between a 531A (turbocharged aftercooled) piston and a 531T (turbocharged) piston is in the bowl and the compression ratio it makes. It s probably not much either, but enough I wouldn t mix pistons.
The 531D non turbo engine would have a completely different piston and possibly cylinder head if Deere kept up with tradition.
(quoted from post at 05:33:37 05/08/20) The difference between a 531A (turbocharged aftercooled) piston and a 531T (turbocharged) piston is in the bowl and the compression ratio it makes. It s probably not much either, but enough I wouldn t mix pistons.
Right I have a four 6531A that can be returned, 6531T "high compression pistons" are still all avaliable through deere. Too MikeJM's point they can't be much more compression then low compression pistons, its not like they are adding compression rings... im going to order one 6531T piston and mic everything out and see. Correct me if I'm wrong on this!
Thanks Pat
I entered the below on the internt... several for sale are advertised as avaliable.
JOHN DEERE 6.531A PISTON KIT PLK225 AR53227 AR53226 R48350 5400 6030 7520
Hope this helps....
I have no conection in any way with the internet parts..Bob...
Pat,
What you are going to find is the combustion bowl in the piston will be different volumes between the two. The compression ratio is a function of the volume of the cylinder at TDC divided by the volume of the cylinder at BDC, the piston bowl volume is where the majority of cylinder volume is on a direct injection diesel.
