John Deere #9 sickle bar
Thilton
I also have #9 sickle cutter. The adjustment bar is frozen up can t seem to move it. Have loosened up the adjustment bolt but still can t get it to move. Is anyone else having this issue.
"[b:654c4848f0][i:654c4848f0]The adjustment bar is frozen up can t seem to move it[/i:654c4848f0][/b:654c4848f0]"
Which part on the mower needs adjustment?
Take a look at the [b:654c4848f0]DRAG BAR, PULL BAR, YOKE, AND TILTING LEVER[/b:654c4848f0] diagram below.
Note the tilting lever (Key 19), yoke (Key 27), and drag bar (Key 29).
The tilting lever is attached by two caps screws to the yoke.
The yoke pivots forward and backward on the drag bar.
This is one method of adjusting the tilt of the cutter bar.
Apply your favorite penetrate between the yoke and drag bar.
Tap the base of the yoke with a small hammer to "[i:654c4848f0]absorb[/i:654c4848f0]" and distribute the penetrate between the drag bar and yoke.
Use a pipe wrench and cheater pipe at the back of the cutter bar next to the inner shoe to either pull forward or push backward.
Putting a cheater pipe on the tilt lever is not recommended.
Continue the repetitive process (penetrate, tapping, pulling/pushing) until the yoke is no longer "[i:654c4848f0]stuck[/i:654c4848f0]" and moving freely on the cutter bar.
Be patient; keep in mind the yoke and drag bar did not "[i:654c4848f0]seize[/i:654c4848f0]" together overnight.
Hope this helps.
Thanks for the schematic and advice. I?ll put some penetrating oil on it tonight and start trying to work it back and forth. I was also Leary of using cheater bar on leaver. I like your idea better. Thanks
