Derweibhai
Can you just remove the rubber fan, insert the required shaft spacer and reassemble with the friction fan parts, or do you have to remove all the rubber fan parts on the radiator end of the shaft and install new friction parts like washers, bearings and the new felt with retainer?
I have a 36 A with rubber fan and a 37 A parts tractor that I took the friction fan parts from including the spacer for the shaft. I couldn't do a direct swap due to the parts tractors gears being overly worn. I want to just remove the rubber fan and drop in the friction fan but don't know if the spacer for the shaft will fit with the rubber fan shaft internals still in place. I know that fella out East sells the conversion parts, but since I don't need a spacer I was hoping to avoid buying any more parts.
Thanks for the help.
