My daughter and I have been working on a 1950 JD A for sometime and ran into an issue with the rods and crank. The crank is original to the motor but the rods and pistons are not. They were beyond repair. We used plasti gauge and got the .003 per the service manual but as we turned the flywheel there is a spot it would get really hard to turn (had to use big pipe wrench to turn it. Also, there is certain spot the rods are actually "wobbly" on the crank. I thought the crank may have been egg shaped so I measured it the best I could vertically and horizontally on both journals. For #1 I got 2.9323 vertical and 2.9345 horizontally. On #2 I got 2.9385 vertically and 2.94 horizontally. I didn't think that was to "egg" shaped but I may be wrong.
Can someone help me and explain how I can measure the rods because it has shims. Also, if I am going at this completely wrong please tell me. I would prefer not to remove the crank because it is a major undertaking. Anyone's help would be graciously appreciated.
