John Deere AR Clutch
I have the clutch apart to inspect and clean the parts. Now I have the whole pulley assy. off and my question is .. I want to disassemble to clean parts, I have the bearing out (no problem) but I want to remove the drive gear from the pulley .. what hold that gear on so tight? it looks like it should slide off.. (or is it pressed on) I see a keyway and key. I have a gear puller on it and I put some heat to it but I don't want to heat to much because I don't want to disturb the bronze bushing inside. So that is why I'm checking in here for help. Or should I just leave well enough alone. Thanks Randall Miller in Ohio
I think that gear is best left alone and on the clutch...
You do not want that gear moving around ..!
That gear is pressed with heavy pressure and heat..I would say, leave that one alone..
Ron.
If there's a real reason to replace that gear, take it to someone who knows how to do it and has done it before. If pressure is put on the assembly in the wrong place to remove the gear you'll be looking for a whole clutch assembly. The whole clutch pulley will be ruined if it's done wrong.
