Friends 1950 AR stopped suddenly while running. If you rotate the flywheel the governor, hydraulic pump, distributor, and fan shaft does not rotate.
I had the end plate off the left side of the governor and gear looks good but doesn't rotate when flywheel is turned.
Both pistons are moving but haven't went any further to check crankshaft gear to valve train etc.
Any experiences or ideas of what maay have happened?
Thanks and much appreciated. Ellis
