LipRipper3006
Reassembling the 50' Model "B" that I pulled from the weeds and just got it running again. I tried moving it around the yard a little bit but it seems to have an issue with the clutch. It was a little jumpy
when taking off and seemed to pull down the engine more than the other tractors I've driven. At first, I thought the clutch was too tight so I backed off the castle nuts a little which seemed to help a tad but
it still would load the engine with the pulley engaged in neutral. Next, I adjusted the flywheel endplay out to .015" and it didn't change anything so I put it back at the original setting of .006". I pulled
the tractor back inside and pulled the clutch assembly down to the driver and turned the pulley by hand and it spun freely with no tight spots or excessive drag. I greased the bearing for the pulley when I had
the tractor tore down and the only part that was replaced was the sliding disc because it was cracked. I reassembled and readjusted the clutch and it still seems to pull the RPMs down in neutral. When pushing
the lever forward slowly like you would when taking off the pully turns slightly but then stops and begins to load the engine until you move the lever more it will stop making a slipping sound and turn with
the engine. When you disengage the clutch the RPMs will rise back to normal and the tractor will idle again. It has me stumped and can't think of anything else it can be. Any Suggestions?
