So I inherited a 1948 John Deere B. It had been parked outside for over a decade. I replaced the carburetor, rebuilt the magneto and whole ignition system, rebuilt the cooling shaft assembly, installed a new sediment filter and oil bath, a new battery, new bunch of stuff. I changed the motor oil and there mustve been an inch of water in the crank case, I suspect from rain running down the exhaust for years. At any rate, I got it popping, but it was very weak.
I tinkered with the carb per instructions and it got better, then a little better. Making a little progress each time. Then yesterday it went off. The sound changed, it got quieter, smoother, and picked up enough power to go scary fast. So much new power I had to adjust the clutch so it wouldnt slip.
It musta been running on a single cylinder before, and now both cylinders?!?
At any rate, now Im getting a bunch of white/gray smoke especially at higher RPMs. Its also spitting out droplets of oil, enough to speckle oil rain on the hood. Im thinking the cylinder that wasnt firing before, but is now, maybe had a stuck or broken ring, valve with a broken spring or is out of adjustment, bad head gasket??
I have a compression test kit, and thats my next plan. Is there any chance this isnt badly damaged engine internals? Has anyone experienced this and have a theory?
I feel really dumb, but not having a good running JD-B for reference makes this difficult to know when Im getting it right.
The bugger-all is every time I run it, it gets stronger, but sprays more oil and makes more smoke.
