John Deere B
kRM1976
When I hook the battery up on my B it arks, I think I tracked it down to the Magneto but not sure what is causing it. It gets burning hot without doing anything
A magneto is self-contained. It should have no connection to the battery. The only wire on a magneto would be a wire to a switch that will ground it out to the chassis to shut the engine down. If there is a wire from the battery to the magneto it is wired up wrong.
Some had a distributor that looks just like a magneto and were not much good. It could also be your voltage regulator stuck closed trying to spin the generator.
Not my tractor, I replied to the info he provided.
There is likely more to the story. The OP is not a new member and has past posts/threads, I am trusting he knows he has a magneto on his B. Looking at his recent posts, he was asking about converting a B from 6-volts to 12 volts. May be there is some undisclosed relationship to that.
As others said, a magneto has no battery connection.
A six volt coil will get hot with 12 volts applied to it, and you would see a slight spark when you connected the battery if the ignition is on and the points are closed.
You can connect a test light between the battery cable and the battery post. If there is a load on the circuit the light will light and you can safely investigate/change things until you find the problem.
In your post in September you are asking about converting your tractor to a 12 volt system. Are you or did you do this? If so did you install an alternator? If so the electrical system very likely has to be changed to negative ground unless you purchased a specialty positive ground alternator. If the wrong polarity is fed to an alternator it creates a dead short.
It also frequently causes a dead alternator.
Looks like some background as to what lead to this (battery being hooked up) are needed. Were you doing the conversion you were asking about? If it was running ok and you just unhooked the battery and didn't do anything else to it, it does not make sense that it sparked. The missing details may count.
