John Deere B
James Williams
I am working on a JD B that I call a 1941 simply becaues someone told me that it was.The serial# is missing.Is there other numbers that I can go by,such as casting # to make sure
jimmy
Does the tractor have a powerlift and if so what is the serial number on it? I have a few listings from other tractors and could probably tell you what year it is if the lift is original. The maincase heat code can only be used to roughly date the tractor within a given year. After about June 38 the heat codes are just 1,2,or 3 digit sequential pattern numbers without the year code.
Pictures and part number/serial number breaks is the way to determine the year if no powerlift is present
