john deere cam grind advice
ricflair
I am restoring a B, exhaust cam lobes are worn, would like to get it ground with a more effient profile.
Who should I have grind it? I hear good things about Bullet. Has anyone used extreme pulling parts? I think Denglers is out of business?
I have had 2 ground by josh Blackburn in Michigan done good job also It will have be degreed in
when installed thanks TVMAN
It's to complicated to explain here. But
just ask Google. I have just done it 2
times, both times the cam grinder had it
dead on. You will get a spec sheet with
your reground cam. Might have to make a
offset key for your crank gear or get
another key way made in it. Or maybe
change the cam gear key, to a of set one.
Of course you need a.dial.indicator. They
really run good when everything is right.
Also I would find a good speed shop and
get everything balanced. Your flywheel is
probably off the most.
