John Deere Connecting Rod Reference
I don't own every tractor manual and sometimes don't have the ones I do have with me. Is there a place in the John Deere world where I can get connecting rod measurement details? For example, I'd like to compare sizes of a AR86981 from a John Deere 329 diesel engine and AA2210R/A2344R from a John Deere A. I don't mind doing the leg work to find the information I am seeking but I haven't found any measurement details during online searches. Is there a reference site for something like this?
I come up with the AR86981 number being for the 404 engine? I have a 4020 service manual (JD) I could copy and send you if that might help.
email is open
Good luck
cnj152
They may use the same part number between engines. I saw the reference to the John Deere 329 engine used in the 6600 combine in some historical threads on here. When I looked up the parts that was the same number used in the 4020. I am just trying to close the loop on some information shared on past threads.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=jd&th=304638
Here is another past thread. I am just trying to understand where the commonalities exist that would allow these connecting rods to be used.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=pulling&th=38231
StrikeForce Found on Clevite catalog the rod dimensions for the 329 diesel. Don't know the length or pin size.
329 CID (5.4L) 6329T Turbocharged Diesel 6 Cyl 4.016in./102mm x 4.330in./110mm Rod Bearing(6) TM-112 CB-759AL STD,10,20,30 2.7480/2.7490 0.0015/0.0045 0.0750 2.9000/2.9010 1.1860
Journal size clearance thickness rod bore width
A2344R is a babbited rod but same as a 60 size. 1.7500 wrist pin. 13 inches length. Hope this helps. Lynn
321 CID (5.3L) 60 2 Cyl (1955) 5.500in./139.7mm x 6.750in./171.5mm 6 Rod Bearing(2) TM-77 CB-468P STD,20 2.9985/3.0000 0.0015/0.0046 0.0745 3.1500/3.1510 1.8500
StrikeForce Did some research and found the AR86981 came out of a 4020 Diesel and like machines. Lynn
381 CID (6.2L) 381 Diesel 6 Cyl 4.125in./104.8mm x 4.750in./120.7mm 32 404 CID (6.6L) 6404D Diesel 6 Cyl 4.250in./108mm x 4.750in./120.7mm Rod Bearing(6) TM-112 CB-669P STD,2,10,20,30 2.9980/2.9990 0.0015/0.0045 0.0955 3.1910/3.1920 1.3900
(quoted from post at 19:52:10 12/13/15) StrikeForce Found on Clevite catalog the rod dimensions for the 329 diesel. Don't know the length or pin size.
Thanks! I am checking out that website and looking to see if I can glean any additional details. I think what I am looking at is the A has a 13" rod with a 3" crank pin while the 329/404 has a 9" rod with a 2.75" crank pin (that matches some numbers I have seen scattered about my searches).
