bmack95hd
- Location
- Cahone, Colorado
Some one may have posted on this before, first time I?ve seen it. Farm Show magazine. Yes that orange reel is your extension cord. Interesting just doesn?t seem practical. What do you think?
(quoted from post at 15:03:39 08/02/19) Something doesn't add up here...
The tractor is 100kw, with 200kw available for implements.
That's 300kw. Even at 480vac 3 phase, you're looking at 360 amps, plus 20% for motor load, that's 432 amps.
Calculate the 3000 ft distance, that calls for 1250MCM wire size, x3, plus a ground.
1250MCM wire is aprox 1" diameter!!! Not counting insulation...
So that "extension cord" will be what, 5" in diameter!
Not quite what the picture is showing!
Unless they are running some extreme voltages, which would not be practical in that environment, what gives?
2,500 volt splice is not likely done with Duct (or Duck) tape!(quoted from post at 18:25:31 08/02/19) I wonder how many splices the cord will have in a few months? Stan
(quoted from post at 16:31:27 08/02/19) It not a new idea, tried on the Kemp tractor in mid-Canterbury, New Zeal;and in the 1930s. Initially on Hart-Parr tractor frames, but also on a Caterpillar.
