John Deere Gator
Railroader01
I have a John Deere Gator 6x4 with a FD620D engine. I replaced the water pump but it will not pump water?? Could it be the water pump cover worn??
Railroader, welcome to YT! I do not know if the JD
Gator has special equipment like an air bleeder but it is
not shown in the attached engine manual. The manual
is from Toro but for the Kawasaki FD620D engine. Go
to ..Coolant.. in the list and click on it go to page 3-8 it
gives the air bleeding steps there. Is the engine
overheating due to lack of circulation? It has a
thermostat so it will not circulate until the temp is
reached for it to open. If you left it set overnight the air
may work itself out after setting. Most all thermostats
have a small air bleed hole in them. Always when you
have a mechanical question or problem web search
what you are looking for. I searched ..FD620D coolant
vent.. and that manual showed up as one of the
results.
Toro Kaw. FD620D manual
