John Deere GT235
Larry2809c
We have a problem with the forward and reverse pedals. When moving forward, and we remove our foot from the forward pedal, the tractor continues on and very slowly the forward pedal will return to its neutral position at which time the tractor will stop. The same for the reverse pedal. It seems like the two pedals need lubricated as they move very slowly. I cannot see anything that is binding or any place to grease. Any ideas on how to correct this would be appreciated.
(quoted from post at 23:13:31 04/30/09) We have a problem with the forward and reverse pedals. When moving forward, and we remove our foot from the forward pedal, the tractor continues on and very slowly the forward pedal will return to its neutral position at which time the tractor will stop. The same for the reverse pedal. It seems like the two pedals need lubricated as they move very slowly. I cannot see anything that is binding or any place to grease. Any ideas on how to correct this would be appreciated.
Check the shock absorber. Might be sticking. If you take it off, it should pretty much throw you over the hood if you go full throttle and let off the pedal fast.
