John Deere GT262
  • Thread starter Thread starter SJ
  • Start date Start date
SJ
I blew the main drive belt.No steps in manual to replace this.Looks pretty complicated up in there.Lots of guides,etc.Anybody ever replaced one of these?Maybey a shop manual?Can you do it from bottom,or you gotta go through the top?
Thanks
Stan
i replaced both belts on my gt 245. both done from underneath. there is one bracket on the very back that needs to be unbolted, it is a guide that holds the belt on the rear pulley. not a bad job, about half an hour. tennessee creeper is real nice to work off of. (big piece of a cardboard box to lay on)
Well the shop wants 250.00 for the job including pick up and delivery.The belts only 20.00.So I am gonna try it,dont look too bad under there with the deck off.I already have a problem.I have to remove the electronic clutch.When I turn the bolt holding up the clutch the clutch turns.Whats the best way to hold clutch without tearing something up?
Thanks
Stan
No my mistake,didnt have to pull the clutch,I think? I got the belt off,so should I assume I can get a new one back on?Cant get one till tomorrow.Theres an adjustable tension pulley I had too remove.How tight should new belt be reinstalled?
Thanks
Stan
the belt tensioner on my 245 automatically sets the belt tension. if i remember there may be a couple belt guides that either get loosened or removed. the electric clutch should not have to be removed.
