John Deere H (1941 Model)
Ag. students are restoring my JD H. for Ag. Mechanics Contest. Having difficulty getting the clutch adjusted. Any thoughts? Also having difficulty with the flywheel moving on the crankshaft when running. Tightened all the way down. Searing for other options to keep flywheel in place.
H's are a little more difficult to set crankshaft end play as you can't directly get to the L.H. end of the crank, which must be pushed to the right to slide the flywheel in. I remove the engine cover and use a piece of wood as a pry bar to shove the crankshaft to the right, then while hold in it push the flywheel all the way on to the crankshaft. That should put the end play about .010-.015" when it is tightened. The H clutch shaft/lever combination is splined and can easily be assembled incorrectly if not marked when it's disassembled. Maybe that ios what your problem is? If so you will just have to try different combinations of lever/shaft/fork until it works right.
FYI: The model H has a groove around the end of the crank and notches at the splits in the flywheel.
These are to allow you to put a pry bar in there and pull the crank into it farther.
If you have an electric start model the optional adapter for hand starting will be covering this and have to come off.
