John Deere HH manure spreader
I am looking at an HH spreader to buy. There is a football shaped cam on the left drive axle. It affects or drives a part, which is missing, on the bed feed/drive chain. I looked at the Model H next to it but what appears to be a gear reduction box wasn't hooked up. Can anyone tell me what that part is, how it works and how much a replacement would cost? Does anyone have a diagram? The asking price is $500. Is that reasonable for Texas?
Matthew,
The "football-shaped" part is called the Feed Cam and Pawl Holder. The part missing on the HH is the Feed Ratchet Case, which primarily contains a 60 tooth Ratchet Feed Wheel, a pawl, and a spring.
When the rear axle rotates forward the lobes of the Feed Cam contact the roller on the Feed Ratchet Case rotating the case in a clockwise direction (looking at it from the left side of the spreader). The Ratchet Feed Wheel is also rotated clockwise by the Pawl, and since it is keyed to the rear apron shaft, the shaft also turns and pulls the apron towards the rear of the spreader. When the lobe passes the roller, an external spring pulls the Feed Ratchet Case back counter clockwise. The pawl ratchets back on the Ratchet Feed Wheel with the wheel not moving. This cycle is repeated as the next lobe contacts the roller.
Email me and I will scan and email back this portion of the Model H parts manual.
