John Deere jumpy rockshaft
VFP
The rock shaft on my 435 raises and lowers properly but jumps constantly after it is raised, worse with a load and with higher rpms.
you have a leak if not on the outside then internal, worn piston seal, leaking lift relief valve, leaking control valve ect. allowing the lift to lower enough to active the control valve raising the lift back to its set position.
