John Deere L
dalet1945
Rebuilding John Deere L. I have looked on Yesterday Tractor & Steiner and find very few parts for the JD L. ie. Complete Gasket Set; Wrist pin Bushings; Cam Bearings & idle bearing; Clutch; All Seals. These are the key items. Not sure if I have a JD Engine or Hercules Engine. What is the key to determining if a JD Engine? Thanks for any help.
The JD engine has the clutch bell housing cast as part of it.
The Hercules engine has a removable bell housing from the block.
That's about all know for telling them apart.
Pick up one of the trade magazines dedicated to John Deere's and there are a lot of ads in them. Might still be some that handle those parts ?
Mike is correct on the bell house. There is an out fit called Ridenours (spell) that deals with L LA Look them up on the web. They can be a little hard to get parts for but they are available as a rule.
If for the JD engine, I got most of my parts from john deere. But front cam bearing can't be had, it doesn't use wrist pin bushings, main bearing inserts are no more, had my rods rebabbited and they used my main bearing shells and relined them. Pistons, rings, valves, springs, gasktes, front crank seal all came from JD. The rear main seal I got from napa.
