John Deere-Lanz 710 1967
Ferda
Not sure where to post this but I have 67 JD lanz that needs a clutch plate and release bearing and I haven't bee able to find any parts for it anyone have any leads or know of another model that may have similar enough parts to make it work. Thanks
Are you in the USA?
Lined traction clutch plate is #AL16777, nla from DEERE, GOOGLE the number, there's lots of sources.
Complete clutch assembly is #AL15970.
Throwout bearing part number was #AL16333, replaced by #AL120097, still available through your DEERE dealer. EXPENSIVE, though! Try GOOGLING the numbers I posted for aftermarket alternatives.
John Deere parts lookup for 710
Up in canada so close enough to order from there. Thanks for the part numbers I'll check those out right now. I did have my local dealer look up parts he said they were obsolete though and couldn't get them they do mostly construction and forestry john deere stuff though so maybe that's why
You have 2 clutch plates in there it is a dual disc clutch. I have a 710 and a 510. I believe they take the same clutch plates. Last one I did was in the 510 and I got the 2 clutch plates at dealer but they could not get pressure plate. I have heard from someone that even the discs are nla, but have not checked myself. My first call if that was the case would be to Diamond Farm near Brighton Ontario 613-475-1771. Ask for Lance. Great guys to deal with. Good luck. PS 710 is a decent tractor. Lot of people bad mouth them, and ya hydraulics are not great, but very handy tractor and sips fuel.
Ok I think I found a place down south thatll rebuild it have to call them tomorrow if it doesn't pan out maybe I'll give that place in Ontario a ring. Thanks for the help. Nice pic by the way
