john deere lp
(quoted from post at 16:42:40 09/21/07) How many 730 lp were made from factory? How many 70"s and 60"s? Please help.
60's= 3808 General Purpose,- 15 Hi-Crops,- 25 Standards,- 45 Orchards
70's= 6254 General Purpose,- 28-Hi-Crops,- 336 Standards
730's= 3263 General Purpose,- 28 Hi-Crops,- 220 Standards
Thanks for the info. I found a 730 on lp he wants 2200 ran good and now all of a sudden doesnt run. Is that a decent price? Probably coil or condensor or lp vaporzer regulator. Right?
Price sounds OK. I would not think there would be a big problem to get it going again. The oil cup needs to be full on the LP to run correct. Did it run and just die or was it shut down and wouldn't start? New points and plugs never hurt anything. Can you pull start it? If so it could be that it is not getting the 12V to the coil it should get for starting. If it will pull start you may have an open resistor, bad switch or broken wire between the switch and coil. Do you hear the "click" of the fuel strainer when you turn the switch on? Check that it has fuel. Empty fuel tank happens more than you think.
