Mountain_anderson
Hi all
I have a Deere 11a with the LUC motor, I've noticed some strange issues with. When I bought it, it was seized and I got it as unseized as I could but it was still hard to spin. I noticed when it spun, the exhaust valve wouldnt return to the down position and found it was slightly bent so I replaced it. I also noticed a small but serious dent on the edge of the piston. I pulled it out and it crunched down on the rings and cracked it, so I bought a replacement. After removing the whole piston, the motor freed up a ton. I also removed the other as I plan to change the rings anyway. I spun the motor a few times with the pistons removed and as I did that, I noticed every now and then, I noticed a ratcheting sound and a rough stop when I spun it. Not sure if it has anything to do with the camshaft or what. Looking at it from the holes to the bottom end from the valve area, it spins fine. But I also noticed the same side intake valve was stuck as well. The cracked piston and both stuck valves are all on the same side. What all could this be? Overheating motor in the past? Is this all repairable? The exhaust valve seemed not to need a new guide even though I bought a replacement, there was no play when I inserted it. It is hard to see the bottom as I have no engine stand and its just placed on a homemade wooden stand I made.
