John Deere LX 279
Hello, I have an LX 279 with the water-cooled Kawasaki engine,the engine struggles,slows down and dies as soon as I put aload into it.I have tried cleaning the underside of the deck and raising the cutting height but does not help.Any one with any ideas? thanks for the help Larry
You should check the fuel flow to your carburetor
as the engine may be starving for fuel. Check the air cleaner too. Hal
I got the LX279 corrected,After I did a comp. test both cyl. at 170 I decided to check the oil and found that it was slightly overfilled maybe 1/5th of a quart.that is all it took to bog her down.Remember the old saying,I would rather run it a quart under than a quart over.
