John Deere M front light mounts
Cavalier
Where do you secure your front light bracket to the tractor? The bracket is M 646 T. I thought it might secure to the support AM2852T. It does have a hole in each side. I question that though. Also, although I see photos of M's with only one front light an one back light; is it common to have 2 front lights. I am just trying to restore to close to stock.
Yes it bolts to the radiator support bracket. As far as how many lights, it depends on the area and use. In my area all I've seen are one left front for cultivating and
the right rear for plowing.
Yes it bolts to the angle iron bracket between the radiator and block, same as the coil.
I put a second light on my M when I restored it.
