MikeandKeri
- Location
- N E Wa
I would say your “option” idea is probably 99% correct. No idea for certain, but the parts diagram I attached shows a bracket it would mount in, unless that was only a support bracket that went behind the hood. My point is that someone may have drilled this hole and mounted it there, but Deere may have intended it to mount elsewhere.That's a new one on me. I've never seen that before. I grew up on an MT, and that never had one. Presumably it was an option?
That’s awesome that it was an option and that it’s in the catalogPer the parts catalog.
JD M parts catalog
Thanks. I’ll look for that today.There should be an oil pressure switch near the oil pressure sender that only allows the meter to run when the engine s running.
Is it mounted in the same area?We have one a John Deere 40U.
I think some farms put them on all their tractors if they had a lot of employees. They could be mounted any place.Is it mounted in the same area?
And a lot of other tractors too.Hobbs hourmeter. Was an option for that tractor.
Ours is mounted on the dash plate. Reads 5400+ hrs.Is it mounted in the same area?
