John deere M leak
Byron James
I have a John Deere M tractor which leaks some around the touch O matic. I am not an expert on this tractor yet, but is there a gasket that could possiable be cracked.
thanks
I restored my JD M recently, and went through the Touch-O-Matic. When I fired it up, I had an annoying small oil leak from the Touch-O-Matic. It turned out to be the cork seal around the control lever shaft. I went to Deere and got another seal, but this time I ground the end of the shaft down so it had a bit of a point on it. This precluded it from tearing the cork as the shaft went back in. These seals should have been rubber, but they are not. The only other gasket is around the can on the front. It shouldn't be leaking. Good luck. They are a chore to change while the Touch-O-Matic is on the tractor.
