John Deere M thermostat
FWB in SK
Has any one tried installing one on a John Deere M. Would it work without water pump. Some one took the shutters of the tractor I have.
There"s a guy in Green Mag who makes shutters including the ones for an M. Are you trying to cool the tractor down or get it to warm up in the winter?
I think the shutters he sells go for around $300 or so for the M series. I have no idea about a t-stat though it sounds good on paper. I don't know how you would get one to work right in the thermosyphon system. Maybe someone else can chime in.
Might work ok if not working it very hard...
The free-flow would not be there, for "Thermo-Cycling" to occur, with the pipe narrowed down for a thermostat..
Shutters work quite well..or, just leave the coolant level below the "High Point" an inch or so..so the coolant needs to heat, before it flows...
It helps...won't get it to 170 probably, but will make it run warmer..
Ron..
Most Ms and MTs get complaints from running too hot, actually just a sensor location problem, than complaints from running too cold. Thousands of them have been running for 50 years or so without thermostats nor shutters and getting along OK, so why worry?
Simplest solution would be to raid a salvage yard for an electric cooling fan . A 12V fan on 6V will flow 1/4 of it's rated but it doesn't take much to cool a M that's putting around at a show.
