Install new points in distributor, gap them at .022. spark plugs look good, gap them .025 as manual says. I put in 3 1/2 gal.s of water in radiator. cleaned the fuel sediment bowl, then put in couple gallons of gas, opened up drain on bottom of carb too make sure it was getting gas. Turned ignition on and checked with meter to make sure there was voltage at distributor, correct voltage. Push starter rod, wa la it fired right up on first crank, and set there and purred like a kitten..
I found one problem, Fuel Sediment Bowl Glass is leaking where it screws into the tank. I drained the tank, took out the sediment bowl and will apply tef tape on it tomorrow. Put it back in, put in a small amount of gas to see if it still leaks. Any suggestion on stopping leak.
Thanks
Thanks
