JOHN DEERE MANURE SPREADER PART NEEDED!
farmtractor1
I HAVE A JOHN DEERE 34 MANURE SPREADER. IM LOOKING FOR PART NUMBER AC14028. ITS THE END GUARD THAT IS ON THE OUTSIDE OF THE SPREADER THAT SECURES THE BEATER TO THE SPREADER ITSELF. (SEE ATTACHED PICTURE PART #1) IF SOMEONE HAS AN OLD SPREADER THAT THEY ARE PARTING OUT, PLEASE LET ME KNOW. THANKS
You will need to post more times (or ask for permission in sight comments to the left. before pictures are allowed. Please use upper and lower case typing. Using all caps is considered shouting, and hard to read. Jim
If you can't find one (Key #1/AC14028) would be VERY simple to fabricate, IMHO, just a short length of tubing and with two mounting tabs welded to it.
If you post using Modern View, you can add pictures after you have one text post on record. Classic View requires 5 text posts on record, so if you are using Classic View swap to Modern View and you should be able to post your pictures.
The size limit for both is 7 to 7.5 MB picture total in a post, that can be one picture or 10 as long as the total is less than the size limit. Phone pictures sometimes need to be reduced to post.
