John Deere, model 44, rope pull plow
I'm trying to remove the left wheel [clutch side] from the axle.
I removed the cap, I removed the pin from the axle. The wheel will
slide a little bit on the axle, but will not come past the edge of
the axle. It feels like something is holding the wheel on the axle.
The three bolts are loose. Also, if anyone has a manual, that they
would be willing to sell, please let me know.
Thanks, Dwight
The wheel is a tapper press fit onto the hub. You need to rig a puller to get the wheel off the hub.
Been a while since I had mine apart but I think that you have to remove the nuts from the bolts. Then the wheel will come off. Then the piece behind needs to be turned maybe 1/4 turn to remove it.
Just clean and enough anti seize to cover to help in dissembly again years later and assemble and bolts will tighten it up
