John Deere model L Tractor
BMAN
If someone has a model L would you measure from the bottom of the front axle to the bottom of the spindle and then email me. Thanks. I want to make sure my L is a high clearance or not. I've been given conflicting measurements.
(quoted from post at 00:38:29 05/16/16) If someone has a model L would you measure from the bottom of the front axle to the bottom of the spindle and then email me. Thanks. I want to make sure my L is a high clearance or not. I've been given conflicting measurements.
Mine Hi Clearance is 10.5' from bottom of the axle to the bottom of the spindle. Approximately 15.5' from the top of the spindle to the bottom of the spindle.
https://photos.yesterdaystractors.com/cgi-bin/gallery/gallery_pic.cgi?pic=http;//photos.yesterdaystractors.com/gallery/pieces/c51396.jpg&firstrec=5769&Parameter=&w=pieces&cc=0&s=
Check out Vintage Tractors, it may help...
[/url]http://www.vintagetractors.com/jdlfront.html
Bman I found on e pic from the last post! You have a lot going on with that L
Does it have a serial tag? From that Pic i'm 95% sure its NOT a high clear axel! It looks like a late 1945 or 46 LA adjustable axle Also it has offset front wheels and looks like you may have 24 inch rear tires and rims??? Couple more pics would help! Chris
here it is
is the serial tag on it? List the serial # for me ! It does look like a LA tractor rear wheels are LA 24 inch not L 22 inch it does have L fenders on it not LA the whole front end looks like a LA ajustable front! NOT A HIGH CLEARANCE Post the serail # Chris
Some one real messed that tractor up? It has a herc motor in it I think it started as a L but someone put a ton of LA parts on it
Butto answer the first question that is not a high clear axle!! Chris
BMAN:
I just went out top the barn and measured my John Deere Model L/Hercules Engine. All original with actual s/n in the 634---- range. The distance you are asking about is exactly 9 inches from bottom of axle to bottom of spindle(both sides the same). The front axle on my machines is non adjustable, fixed.
Closer view of your front end reveals that it has the adjustable front axle. At the time of purchase or later the adjustable front axle was available from the dealer for these machines. The same was true for the Model LA. For 38,40,43,48 and 52 inch front wheel treads an adjustable front axle is/was available. This is taken from the spec sheet for models L and LA. My spec sheet book was published in Sept 1941.
Looking at your "propeller shaft cover" which is narrow your machine never had the shaft bolted together pulley to drive the JD No. 7 integral mower.
