John Deere Moldboard Plow
FarmerDaveo
I have an old Johne Deere plow that was my fathers but has not been used for some time. I would guess it is an early 80's model. It is a 4 furrow, 3 point hitch mount. My question is when greasing the safety trip mechanism is it normal to only be able to give it 3 or 4 pumps? Of the 4 trip mechanisms I was unable to get any grease to one and the other 3 all took a few pumps easy and then seemed to lock up and I could no longer pump any more grease regardless of the pressure I applied. Is this normal or are they plugged with dried grease?
Thanks,
Dave
Both ways are normal. That?s not much help is it.
Probably plugged up, or it has tension on it and won?t accept the grease.
Likely a 145 model?
Paul
If it will take some geese but won?t take very much
a grease buster tool will probably free them up so
they?ll take more
(quoted from post at 10:43:07 10/16/19) Both ways are normal. That?s not much help is it.
Likely a 145 model?
Paul
No visible model number but it is a full mount (not semi mount as the pictures of the 145 model I looked up)
Thanks for the comments, I will try to clean them up and get more grease to them. Just wanted to be sure that was not how they were meant to take grease as it seemed odd that they all took some and then all stopped. Seemed almost if that was by design.
Thanks again,
Dave!
(quoted from post at 09:20:10 10/16/19)
Likely a 145 model?
Paul
Thanks again,
Dave!
If you can remove the grease fittings, unscrew them and apply some gentle heat, like a MAPP gas soldering torch. Just be sure that you don't stand in line with the grease fitting's hole (ask me how I know this...) With a MAPP gas torch, you can generally get the grease hot enough to liquify, and you may vaporize any water that has worked into the joint (which will burst out of the grease fitting hole, sometimes). The good thing is, you won't get anything hot enough to get the metal brittle or anything like that.
So, if you can, remove the fitting, apply some gentle heat with a MAPP gas torch. Let it cool, squirt a little penetrating oil into the fitting's hole. Screw the fitting back in and let the penetrating oil sit for a while. Then try greasing it again.
This has worked for me on fittings that are partially blocked like what you describe.
Yea, fully mounted plows with more than 2 bottoms is rare up here, I don?t think of such a thing.
Paul
(quoted from post at 22:51:51 10/16/19) Yea, fully mounted plows with more than 2 bottoms is rare up here, I don?t think of such a thing.
Paul
Found a model number. It is marked E-0045 so from what I understand it is considered a 45 model.
The odd thing is I was talking to a friend with an International Harvester plough similar design to the John Deere and he says his does the exact same thing as far as taking 2 or 3 pumps and then stops. It almost seems by design that this happens.
