Hello all. I m new here but I m having a seemingly unsolvable problem with my JD no.9 mower. I dug it out of the weeds this spring and started fixing it up. I replaced all the segments/knives and straightened the cutter bar. Then I bought 27 all new rock guards from the local JD dealer which was, lets just say a "few" bucks. After all of this, my cutters won't lay flat on the rock guard ledger plates. They hover about a 1/16" too high. I called the place where I bought the new guards and they assured me that the old number I gave them (H-11132-H) crossed to the new guards they gave me (AE36136). However I took a new guard and an old guard and mounted them on a piece of 1/4" flat steel and the old guards seem to be a 1/16" higher then the new ones (See picture). So I took this assembly to the JD store and was told that this was "the first time anyone has had a problem with these guards". I tried bending them up with a hammer as well, as I was told these guards are malleable, but that didnt work either. They hardly bend, and even if they did the tips of the segments would be in contact with the guards before the base so they would be angled improperly. I live in amish country and so I also had an amish guy who works on this type of machinery all the time come out and look at the problem, he told me I have the wrong guards. So I ve been doing some measuring, the bar the rock guards mount to is 7/16"thick. The wear plates are a little over 1/16" thick. And on the rock guards themselves, measuring from the flat part where it mounts to the bottom of bar to flush with the ledger plate gives me 7/16". A little math gives me a little over a 1/16" too low at the rock guard ledger plate. As for the hold downs, I ve had them hammered down to point where the segments contact the ledger plates but then again the tips touch before rear so the angle is off plus it puts everything in a bind with really high heat friction points. So in the end I have no idea what to make of this. Are the guards wrong? or is the bar the wrong size somehow? I feel like I ve tried everything and I m not sure what to do next.
