John Deere Serial Number
pepstan57
I have a 1951 John Deere B. Serial number is not readable on ID tag. Is it stamped or cast anywhere else on the Tractor?
No. Sometimes if you wet it you can make
out numbers. If not, when you take it off,
you might be able to make out the numbers
from the backside. If those both are no
gos, then sadly you are out of luck.
Get several good photos of it with light from different directions, including with the light at a low angle. Sometimes you can enlarge the photo and see better.
Yes, a camera and a flashlight. Shine the flashlight on the tag at different extreme angles and take the picture with no flash. You can then blow up the picture. Sometimes lightly sanding the tag with very fine emery cloth or 2000 grit sandpaper will help. Just a few strokes at a time to polish the tag is all you need to do. Coarse sandpaper might make slight scratches you might mistake as a partial number. Sometimes the back of the tag will have a slight raise where the number characters are stamped. Let us know how you come out.
