John Deere Spoker D
Bendeere
I have a 1925 D with the 6 1/2 bore. The block is bored .45 over. What should the ring gap be? And also what should the piston tolerance to the cylinder wall be? Thanks can call if needed. 517 610 1282 Ben
ring end gap is .003-.004 for every inch of cyl. bore.looking in the nieghborhood of .020-.026 not sure of piston clearance on those big pistons, but i would think .oo7 would be ok. dont want to get them too tight under load.
Are the pistons aluminum or iron? If aluminum, are they Cast aluminum or billet? Different expansion rates. On forged or billet piston, you'd be closer to 14-16 thou clearance required. Cast, less. Iron, less.
Pistons are supposed to be built with the clearance built in to them for the bore. So you SHOULD bore it to 6.545". Check with who built your pistons to see what they say.
