John Deere tractorpulling
Per Ahlstrom
A friend of mine in Sweden wants me to find a pre 1980 John Deere 2-wheel drive tractor with over 300 hp. He is set to win the local tractor pulling in his county.
Is there such a thing? And if so - does anyone know where I can find one?
What weight?? 6030 it might not be rate over 300.. but its probably making over 300...
JDGnut
It's not rated to be that, only 175on the low side, but like all the other tractors, it only takes a little to grab a lot more horse. A JD guy would know how to find it on a 6030. The 6030's are one hell of a tractor.
The 6030 was made from 1972-1977.
It is rated @ 176 PTO HP
With 531 cubic inches you can make 300 Hp.
(quoted from post at 16:06:16 11/03/09) JDG, You really believe the 6030 is in the 300 hp range?
As Big Jugs said it won't take much.. 300 might be pushing it a little... but I bet most made 225-250+.. many got a few turns.. I've seen stock 466's (w/stock A Pumps) with just the screw turned in some, make 300hp.. 531 with a P would be easy.. change it out for a 619... But if you're going to change the engine out to a 619, you could also look at something like a 5020..
If you don't go with one of those your going to be using a small block deere.. your next biggest would be a 4848.. or 4640.. (I wouldn't want the powershift in the 48.. Yes.. I know some have made it work.. )
Good Luck..
JDGnut
(quoted from post at 19:31:19 11/03/09) Weren't the 5010-20's 531cubes, and the 6030's at 619? Just wondering if that was correct.
6030's were 531.. but had a P-pump, and most had a turbo.. The 5010/5020 had a rotory pump, NA... Different blocks
The 619 (10.1L) only came in 4 Wheel Drives.. Which is why there are complaints in some of the classes when guys put the 619 in the 5020/6030 Chassis.. (The engine was not available in a 2wd or Row Crop configuration..)
JDGnut
We had one on the farm years ago that we bought used from the local JD dealer. He dyno"ed it for us and it was turning 375 HP. We had it turned down to 275 HP and used it for years for our heavy tillage work. The guy who had it before us turned everything up just as much as it would stand.
The 6030 did not come from the factory with a 619 engine. 5010,5020 and 6030 all had 531 cubic inch engines from the factory. The 5010 and 20 had different engines than the 6030 as they were both D series non turbo engines with distributor inj. pumps. The 6030 could be purchased with a non turbo D engine but was very rare to find one that way. Most 6030 came with the 531 A series engine with the large inline "P" inj. pump. This engine was the same power plant as used in the 7520 four wheel drive tractor. The 6030 was allot easier to repower with a 619 because it would fit directly in place of the 531A engine without having to move radiator forward or grind front steering support for pulley clearances. Allot of them were repower with 619 engines as well as were the 5010's and 20's. DW
Every time there is a WTW post, I can't look away. Thanks again for increasing my Deere knowledge. I'm not a big Deere fan, but you really tell us the interesting stuff no one else takes the time to find, learn, or explain.
My MM pulling heads require some Deere valves from a 6030 before I start the porting and valve job work. Might you know the differences in valve diameter between the 531 and 619? I was told turbo and non-turbo make a difference as well. Thanks!
Ethan
Can't tell you actual diameters but, the 6030 531A and early 619 used the same exhaust valve. Later 619 changed from a 45 degree valve seat angle to a 30. Intake valve is different part number between the two. Don't know if it is valve diameter is different or not. The early 619 intake has a 30 degree and went to a 20 degree valve seat angle. Thats all the information I know at the moment on the valves. Good Luck, DW
