John T - Which Generator do I have?
Paul RI
Hey John,
I have read your trouble shooting generators sheet. Thank you very much.
I have also read a TON of generator posts here.
I have a Case 320 Industrial Loader/Backhoe that isn't charging. I tried your suggestions except for the "Motor" test. Ran out of day light.
Took the VR off and opened it up. Three coils, looks identical to a Delco/Remy VR. The field point look like they done burnt away.
Rooting around in the shed, I happened to find another VR in a box of stuff. This one only has two coils in it. The mounting tabs are bent funny and I remembered seeing what looked like extra screws on the Genny's housing.
Well, looks like the found VR mounts on the genny's housing. The screws on the housing lined up with the holes on the VR and the bending fit too.
Now the questions:
How can I determine if the generator is a Delco "A" type or a Ford "B" type?
Will a Delco VR work on a Ford generator if that is my case?
Don't know what "original" looks like for this tractor. I am finding a good bit of "git 'er runnin'" repairs on it.
The prior owner said he had both the generator and VR tested and they were fine, but he never could get the battery to charge. I probably burnt up the field points when trying to troubleshoot before I had your instructions.
I figure I need a new VR at least. I just don't know if there is a difference between "A" & "B"
Please help.
JohnT is on a road trip and MAY not see your post for a while.
You CANNOT mix and match "A" and "B" circuit generators and regulators. An "A" circuit generator MUST use an "A" circuit regulator and vice-versa.
Put a voltmeter between the generator's "A" terminal and ground, then short the "F" terminal to ground. If it charges, it's an "A" circuit generator. (Disconnect the wire from the "F" terminal first to avoid regulator damage IF it happens to be a "B" circuit generator.)
With a "B" circuit generator VOLTAGE must be applied to the "F" terminal to make it charge, just the opposite of an "A" circuit unit the must have it's "F" terminal grounded to charge.
Thank you Bob.
I was hoping there was a simple way. I couldn't see how to differentiate them with a resistance check.
(quoted from post at 21:26:37 06/29/10) Thank you Bob.
If by "simple way", you mean without running the engine/spinning the generator, then you can remove wires from gen terminals, then connect battery to Field terminal (other side of battery to generator case ground). Connect voltmeter, one lead to case ground, other lead to ARM terminal. IF measure zero, then you have a "B-type" generator. IF you measure anything at all, perhaps as little as a quarter of a volt, then you have an "A-type" generator.
