Russ from MN
- Location
- Bemidji MN
Any update on the well problem? Not a good time to work on a well, I see it's below 0 in MN. There's and old saying "colder than a well diggers heart in January"!
(quoted from post at 09:24:41 12/10/19) Jon, what kind of pump? I like Red Lion pumps.
-15F here this morning....a bit too cold for dealing with anything that's wet!
As I've mentioned in other posts, when you pull that pump, it'd be a good idea to add an inline check valve every 100', plus another just above the pump. That keeps all water-hammer effect off of the pump when it cycles off.
(quoted from post at 23:07:06 12/10/19) A larger pump will pump more gallons per minute, so it runs a shorter time!
(quoted from post at 22:34:53 12/10/19)(quoted from post at 23:07:06 12/10/19) A larger pump will pump more gallons per minute, so it runs a shorter time!
Yes that's what I said, larger pump has a shorter run time but the off time is determined by the size of the pressure tank.
The smaller pump will run longer delivering the same total amount of water, but they'll both be off the same amount of time if they are both connected to the same size pressure tank.
If the larger pump cycles 5 times while filling a container the smaller pump will also cycle 5 times, but it will run longer between cycles, unless it's to small to keep up with the flow, then it could run non stop until the water is turned of.
(quoted from post at 10:17:31 12/12/19)
For single use apps what you suggest is good but the average house whole has multi use apps and that's when pressure tank size comes into play.
If I'm flowing 10 gpm filling a tank and the pump is running continuously below cutoff pressure that's fine, but when my shower head is flowing 1.8 gpm I don't want that same 10 gpm pump cycling off and on every 30 seconds because the pressure tank is to small.
In our area wells are deep, one under 200 ft is considered a shallow well.
The minimum recommended water flow to a home is considered to be around 10 gpm so pumps in this area are sized according to hp and stages needed to deliver 10 gpm to the highest elevation the water will be delivered to, there forth the number of times a pump cycles to deliver a given amount of water is determined by the size of the pressure tank, it's size is usually determined by the location and available space for the tank.
