Jonsered chainsaw
Vern H
Hi Gang, I m a refugee from the John Deere forum and have wandered over here looking for some chainsaw wisdom. I have a small, OLD, Jonsered(s) chainsaw that I believe has developed a bad coil. I can t find a model no. on it. On the recoil cover it says- Automatic-. Small chain, 1/4", I think, no chain brake. Same old story, "It ran good when I parked it". It sat for a couple years and now no spark. The local repair shops tell me to retire it and they will gladly sell me a new one. Any one out there have a possible source for ancient parts? Send me a note or give me a call @ 602 819 0567. Thanks, VH
Hello again Vern. Site said private messaging was disabled so here are the two web sites I mentioned.---
http://www.arboristsite.com/community/forums/chainsaw.9/
http://chainsawrepair.createaforum.com/index.php
Have fun!
Hi Den N Ms, Thanks for good info. I did find a tag on it that said it is a type HS which is not on the list of stuff you sent, BUT, by looking at the exploded pics of the early saws I believe it is a model 361. Thank you for the help. VH
Are you sure the points are clean, also check to make sure the condenser is not shorted. I have a Little Jon that I bought in 72, it was made by Poulan, Sears also sold the same saw. It has 1/4 chain, hard to find, but I am only on my second chain in 43 years. It's my carry along for emergencies saw, so it doesn't get used much, but it's always ready to go! I have 3 bigger Jonsereds that do all the serious cutting.
Hi Jiles, Well, you certainly get the star for today! Per your instructions, I spun it with a drill, slow at first and pretty soon I see kind of a poor red/yellow spark, followed by a fat blue one. I put things back together and it lit right off. There are some fuel issues but I think it just needs exercise. Thank you for sharing your wisdom. VH
Hi Russ, This one has an electronic ignition system, so no points. I did get it cranked up with the help of some of the great folks on this site. Second chain in 40+ years? When you decide to trade it in, I m interested:) Thanks for the reply. VH
(quoted from post at 21:23:03 03/13/15) Hi Jiles, Well, you certainly get the star for today! Per your instructions, I spun it with a drill, slow at first and pretty soon I see kind of a poor red/yellow spark, followed by a fat blue one. I put things back together and it lit right off. There are some fuel issues but I think it just needs exercise. Thank you for sharing your wisdom. VH
I've seen that same thing before. Check your grounds for corrosion. It needs to be dry and warmed up and it may well run fine for years more.
(quoted from post at 01:23:03 03/14/15) Hi Jiles, Well, you certainly get the star for today! Per your instructions, I spun it with a drill, slow at first and pretty soon I see kind of a poor red/yellow spark, followed by a fat blue one. I put things back together and it lit right off. There are some fuel issues but I think it just needs exercise. Thank you for sharing your wisdom. VH
Hi Vern, Good to know that it worked for you. Thanks for letting me know--just gives me a good feeling knowing I might have helped someone.
Hi Bret, I think I ll do a ground check even though it is running. That and a carb cleaning help the hard starting. Thanks for the reply. VH
