getting ready pull jubalee in for service work in the I T manual i see it say 0.015 h on valve adjustment is there a cold setting since i will have the fuel tank off
also is there a order in need to follow in adjusting such as which cylinder
thanks for any info
thanks for any info
I&T F0-20 has everything needed. Go by engine size, model means nothing. 134 CID/OHV Red Tiger Engine.
TPD
Hi gcoleman55, welcome to the forum. According to my operators manual for a NAA (Jubilee) It says to bring the engine to normal operating temperature. Then they have you shut off the fuel supply and remove the glass bowl. Then remove the rocker shaft cover, leaving the tank on.
If you already have the tank off, then I might wait until you put back on and then to the adjustment, or just adjust them cold with some extra clearance?
By the way, my I&T FO-19 says to adjust them at operating temperature. Paragraph 21.
i use a lawn mower tank and a $10 shutoff valve to power my 2N when the sheet metal's off.
