Jube transmission flush
ed1
Transmission fluid looking a little milky! I know I need to get tractor warm and drain fluid, flush with diesel fluid and replace with 134D. Should I use a gallon of diesel and run it a couple minutes and then replace fluid. Also rear differential, 90wt gear oil?
Thanks,
ed1
Thanks,
ed1
I would just put the UTF in all three sumps. Like was pointed out to me a few years ago, how do you know the seal between the differential and hydraulic sump is good?
