Jubilee back pressure valve question
Al in Il.
Iv'e posted several times about my Jubilee hydraulic problems. I just removed the back pressure valve, I can't get the spring inside the body to
move at all from either end. The threaded part is still attached to the vale. Should you be able to push or move anything from one end or the
other? How can I safely take the threaded end off without damaging anything? The spring inside appears to be frozen unless massive amounts of
pressure are needed to actuate it. I have used quite a bit of reasonable force. Thank you everyone.
