ericinvermont
Hi there and happy holidays!
I'm new to the forums, but not new to Yesterday's Tractor or to Fords- I've had an 8N for years.
I now have a '54 Jubilee and decided to change the fluid in the three compartments- transmission, hydraulics, and differential- not like the 8N that has one big compartment.
Working from the front, I first changed the fluid in the transmission- no problem. Then the hydraulics- no problem. All drained properly and took approximately the amount the manual says.
BUT! When I removed the differential drain plug (square plug, furthest back on the bottom), I got shock number 1- no oil came out! I stuck my finger up in there and there wasn't any blockage that I could feel. Crap! No oil in the diff can't be good.
I replaced the drain plug and then removed the fill plug as well as the fluid level plug- the last ones to the rear of the tractor. I started adding fluid to the top and then I got shock number 2: nasty molasses oil immediately started draining from the fluid level plug! I put in maybe a gallon of new fluid until the new stuff ran clear from the fluid level plug.
Then I started the tractor, engaged the PTO and let it run for 5 minutes. I removed the fluid level plug and a slight amount came out.
Then shock number 3: I removed the bottom drain plug and again, NOTHING came out!
I'm baffled by this. It's as if the differential oil is caught up at the top and not going all the way down. Please set me straight!
Thanks so much!
eric in vermont
Thanks so much!
eric in vermont
