Jubilee doesn't like cold air
Geo-TH,In
It didn't want to make power. So I put on
4 inch flex hose and cranked main jet out
a half turn.
This happens every winter.
This is my idea. I had a 1971 Plymouth
duster that recovered heat from exhaust
manifold.
That should warm up the oil in the air cleaner. I agree with carburetor readjustment. Another factor may be if you are still running gas from summer/ early fall. In this area there is a winter formula gas that will mix better with air at lower temperature, but isn?t allowed during warm months due to pollution regulations as it evaporates more readily .
It happens every fall/winter. It needs warmer air and a half turn out on main jet. Without it there wasn't enough power to move tractor in first gear.
