Jubilee Generator Pulley
JW Axtell
Any idea where I can locate a generator pulley for a Jubilee?
The non-original generator that I am replacing had an extended shaft with some sort of adjustable (for belt width) Pulley.
The new generator from Yesterday's Tractors has a shorter shaft and wider woodruff key.
Oddly enough Yesterday's Tractor does not list this item on their Jubilee/NAA
parts list
(quoted from post at 15:08:11 09/03/08) I recently bought a gen pulley from my local auto elctric repair shop.
Thanks.
To make matters worse the new generator from YT has a metric thread. I guess I should have researched more before I purchased this new generator. Short shaft, metric threading, etc.
I have a machine shop trying to retool the old pulley but it will probably cost much more than I intended
Well, I guess that was a hard lesson learned. Machinist called today. Re-tooling of pulley was $125.00. The odd thing seems to be that the pulley for a Jubilee generator (or at least the replacement genny that YT sells) is impossible to find. You would think that it would come with it, or at least be available as an extra cost item.
Even if one has, or could locate locate an original genny the pulley is nowhere to be found. It would have been cheaper to go with a 12 volt conversion.
Oh well.............
Is the pulley for the NAA different than a 600/800? I thought they were the same. If so, I have a pretty decent pulley. Email me if interested.
